Tim Moland
It is just bare aluminum. When I ordered the kit, I talked to Adam about the aluminum tarnishing. We looked at his car, and the uprights did not look tarnished. However, the rear shock tower mount plates(also aluminum) did have some discoloration. We speculated that it was because it was a horizontal surface that allowed water to sit in it. I got those powdercoated to match the frame. I could get the uprights clear coated I guess, but they were a pain to get installed simply because I do not own a 15/16" wrench. When tightening the pivot bolts, I had to use my Arkansas socket set, which did not fit in between the black brackets. I had to disassemble each black bracket, bolt it onto the opposite side for support, torque the pivot bolt, and then reassemble the black bracket back to its proper position. So in hind sight, I should have got them clear coated before I installed them if I were going to do it.
