Tim Moland
I've been in love with this color ever since I saw yours. I promise I'll do something different on the hood! Haha
There are only two ground points near there. The petal box and the battery terminal. So. Whichever it reaches is prob best.Does anyone know where this hooks up? View attachment 8402I'm sure it's a ground, but it exits out the front under the battery box.
I know, horrible post, but I couldn't figure out how to post the video. It was late, and I gave up. What's the process to load a video?Do tell!
Upload it to YouTube and then paste the link to it here.I know, horrible post, but I couldn't figure out how to post the video. It was late, and I gave up. What's the process to load a video?
Did your fuel tank come with the washers and nuts on it? I didn’t get any. Are we supposed to use donor nuts?Did a little more plumbing on the master cylinder. I have one more hose for the clutch to hook up. I notice the nipple coming off the reservoir looked a little fatigued at the base from me yanking on the original house to get it off. I decided to JB weld the base to give it a little more support before it cracks. View attachment 8117
Then I moved on to the fuel tank. Got it all installed and the filler neck plumbed. I then noticed that the fuel pump hold down ring is under the fuel tank top frame rail. It is impossible to remove it from the tank without loosening the tank strap and letting the tank relax back. I'm thinking that doing this after the engine is installed will be very hard. Any reason why I can't install the fuel pump now before the engine is installed? Also, does the vent tube in the filter neck get a hose attached right back to the nipple in the top of the tank, or does something else hook up there. I noticed there is a T in the fuel filter neck parts bag. Maybe that goes in between. View attachment 8118
If you are talking about the ring to hold the fuel pump in, then yes it did come with washers and nylock nuts. I believe the ring was on the tank with the washer and nuts holding it on loosely when I received it.Did your fuel tank come with the washers and nuts on it? I didn’t get any. Are we supposed to use donor nuts?
Also, yes, important step to take the ring off before mounting the fuel tank. And BEFORE putting the engine in. Glad I went to put the pump in before the engine.
Check out my thread for info on both of these issues. You want to leave the check valve on that hose. I think the kit comes with an adapter fitting that has the male push-connect on both ends, then a female p-c hose end fitting. I couldn't use them since my check valve p-c fitting was trashed.I had some issues with overheating. I think I got it figured out. See my other post in the Engine and transmission section. I got my cold air intake installed. It was tight. I have about 1/8" of clearance to my coilover. I might take it back apart and trim 3/8" off the big metal elbow so I can snug it up against the frame a little bit more. Right now it's bottomed out on the reducer coupler that hooks to the turbo.
How does this hose hook up to the intake tube? Do you remove it and just run a rubber hose between the two? Or is there a check valve in the original hose?
Do you know what size hose is needed? With the tygon do you need to use hose clamps on the ends? I guess it never hurts...I'm going to use Tygon 2375. Used it for brake fluid applications for years. No swelling, sweating, leaking.
https://www.mcmaster.com/tygon-2375-tubing
