ToothMagician
That looks great, I'm definitely gonna pick some of those up
I will leave those off of your request. Remember, they are just holding down a cover so they do not need to be graded bolts. Get your favorite!That looks great, I'm definitely gonna pick some of those up
This - just loosen up the v band and rotate the turbo.You should be able to clock the turbo housing to gain clearance.
I'm using the F35 driver's side and rearmost mounts for the passenger side IAC with the videos.Which driver's and passenger's sidemount holes are you using? The front-most holes in the mount plates must be used with the TC setup. If using the rearward holes there is reduced clearance for the charge pipes.
And the silicon pipe closest to the turbo has to be trimmed a bit to get the angles correct. This will help some too.
I ended up clocking the turbo, rotating the clamps and adjusting the tubing to clear the cross member. It rests gently on it now and one of the clamps rests on the ignition coil cover, but I think it'll work. I'll take a pic soon and post so y'all can see what I mean.You should be able to clock the turbo housing to gain clearance.
Thanks for the heads-up. I'm not too sure what I'm going to do for an intercooler setup yet. The one that came with the cobalt is too wide to use for the goblinI’d usually ran between the motor and cross member with stock turbo. Causes a little deformation of the silicone tube, but not much. The stock DF stuff probably won’t be enough to connect it to the intercooler.
That's where I'm slightly confused, the intercooler it had was coolant filled, with the dual pass laminova core intake and a second coolant resevoir in a closed system. Should I treat it like an air to air?The Cobalt intercooler is an air-to-air intercooler meant to be mounted where there is uninterrupted 'clean' air form maximum efficiency - and it needs to be close to the engine. This typically means it is mounted up front near the radiator or mounted in a side pod where there is sufficient airflow.
DF supplies an air-to-water intercooler, which can be mounted right at the engine, and an external heat exchanger that get mounted remotely where there is 'clean' air.
You can use the donor intercooler, maybe mounting it above the engine in the turbulent airflow there with a fan or two. Or maybe at the rear, like Justin Reed which seems to work okay for his application - but note his intercooler is about 5X the core size of the donor intercooler.
Personally IMO I would find an air-to-water intercooler that meets your power requirements and use a remote mount heat exchanger (or two). This is as far as using a N/A intake manifold, the LSJ is a different setup and there are several builders who use the SC intake and laminova cores with a remote heat exchanger. There are lots of ways to get your turbo intercooler setup, just keep looking until you find what you like.
I think I understand, I'll check out the pic thread and see if I can figure it outI’m talking about intercooler, not the heat exchange. The intercooler for the df stock turbo set up is mounted to the top of the intake manifold. Look through the helpful pictures thread. There are a lot of turbo pictures there.
HaHa! See what he did there! "Short FIRE"? Like Have an extinguisher on hand during initial start up!? Fire don't PLAY! Don't get burned.Only things required for a first start are:
Fuel lines
Battery cables ran
Grounds connected
Include the turn signal switch, EPS and BCM installed.
For a short fire, not a long run. Longer runs will need all the coolant stuff hooked up.
