Bajakid1450’s ss 2.4sc street goblin build
Bajakid1450
I do wayyyyyy to many engine installations hahah Monday I got 2 to do and 2 removals on another plane to send off to be reman
G Atsma
Too bad those little Allisons (now RR) are so blasted expensive. They are great turbines for smaller single engine craft!
Bajakid1450
Just got some 5052-H38 aluminum alloy sheet metal for front skid plate, It does not really bend it has a very very high tensile strength I got a 4’x4’ sheet for $50 to help protect the goblin from speed bumps and potholes
TheNuker
Pretty sure these seats are calling your name, The backs match your frame!
Nuker-
Bajakid1450
I’d love to get those but I’m needing some heavy duty waterproof seats since I’m gonna be driving it a lot
Bajakid1450
Nuker-
I had bride version of those seats back in 2010 loved the color but the suede wears out after about a year of driving
Bajakid1450
I’m having the hardest time getting these radiator hoses ran through the chassis. I used a whole bottle of tire wet and even used a ratchet strap can’t get the hoses more than a foot before letting go and having to do it again
Put the hose in a box with a heater, and/or heat your shop up. Warm hose = flexible hose.
Bajakid1450
I’ll have to try that this upcoming weekend I was trying to get it done today and start getting the engine and suspension next weekend
Bajakid1450
nobody in my area had “tire wet” in stock ended up using Lexus rubber lubricant/ tire shine. Just got one in with a full bottle and a ratchet strap :) time to do the other that might be the issue tho not being the actual tire wet
Bajakid1450
Nevermind after 2.5 hours I got both of them through. Geez I thought I was gonna break them when installing those hoses !!!
Tie wet is a silicone base lube and is about ten times slicker than tire shine which I think is soapy waster.
