They waved the restocking fee because their descriptions were not accurate. I still had to eat the shipping costs though.Did they charge you a restocking fee?
Running pump gas on the 5th injector was more like an interim step. Since the long term plan is E85, I don't want to add an additional tank/pump for water/meth. Plus having a tune ready for pump gas incase E85 isn't available would be nice, without having to mess with the 5th injector controller etc.I would also consider running water/meth for that 5th injector, rather than fuel
This is where ZZP put the 5th injector on the donor I bought.Is anyone running the ZZP 5th injector kit on their LNF goblin?
I'm considering picking up one of these for E85 fueling + valve washing and was curious if there were any clearance/other issues with how it mounts to the Evap solenoid port in the intake.
Did the 5th injector fit into the base of the weldable bung. The injector that came with the ZZP kit (off my donor) is to large. The id of hole in intake is .472 and the hole in the ampefi weldable bung is .435
Thanks for replyThis is the injector bung I used. I put a Bosch ~40lb/hr injector in it, but the 60lb/hr deka injector would fit in it as well.
I never actually put a Deka in my bung hole... but I can measure the diameter of it tomorrow if you want.Thanks for reply
Looks identical to the one I bought as but must be a different brand. The Deka 60lb definitely does not fit in base.
Yes, the injectors are too small for E85. The LNF is a direct injected engine, and larger injectors are not available (technically there are some Opel injectors that are 13% larger, but that's still not the +30% larger needed to run E85 at reasonable duty cycles).I'm still trying to figure out why a properly set up EFI system needs a 5th injector when a normal system can be calibrated to handle fueling needs without it. Unless of course the E?FI system is NOT properly set up.... like with too-small injectors...
What turbo do you have? And cams? I'm hoping for ~400WHP on my Z54 w/ E85 & stock cams (I have the opel injectors also).Car made 472 at the wheel on ZZP’s dyno
