X2.
When attaching straps around tank be careful of end of strap doesn’t scratch your new paint work
glad it’s fairly hidden.
X2.
Need a tech2 and that's my only option. Jumping poles on the starter will get it cranked but it's not a long term solution.Yeah, those position sensors are real buggers. The car won't even start without those correctly calibrated, is that correct? What's your plan to remedy that? I'll probably follow in your footsteps on that one.
Yeah, I flipped the pump around. I just haven't gotten around to getting a new set of ring priers, the ones I have are the super adjustable ones so they're really flimsy.Did you end up modifying your fuel pump so the lever doesn't get stuck?
HF for the snap ring pliers
I didn't use mine, they are yours if you want.
- I broke one of the 45 degree brass fittings on the brake relocation kit, need to get another.
I think shipping them would cost more than it would be for me to run down to Lowe's and get new ones, thank you though!I didn't use mine, they are yours if you want.
What's your plan for that? Are you going to buy one? Borrow one?Need a tech2 and that's my only option. Jumping poles on the starter will get it cranked but it's not a long term solution.
There are Chinese clones for 300 bucks on Amazon but I'm not 100% sure they would do it because I need software as well, which has been cracked AFAIK but I am not sure I want to spend the cheddar to find out.What's your plan for that? Are you going to buy one? Borrow one?
2 of my friends have the China tech2 and both work well. I have the real deal, because I work on gm vehicles. They all seem to basically work the same.There are Chinese clones for 300 bucks on Amazon but I'm not 100% sure they would do it because I need software as well, which has been cracked AFAIK but I am not sure I want to spend the cheddar to find out.
Taking a trip to GM to have them do it may be easiest and cheapest.
What's the deal with the software part and the Chinese versions? Do they have to do anything special? I'm in SC but thanks for the offer.2 of my friends have the China tech2 and both work well. I have the real deal, because I work on gm vehicles. They all seem to basically work the same.
I’m not sure where you are located, but if you are anywhere near Houston, I’d be willing to help out with it if you want.
If you go to the dealer to calibrate it, also ask them to change your tire pressure sensor settings.
