Parking Brake With Amazon Kit
neodied
Since I didn't save the parking brake cables and tubes from my donor, I chose to use the Amazon kit mentioned in this thread (credit to @Hellproof) :
330-9371 Parking Brake Cable Kit Fit for Wilwood 110" Long Cables with a 97" Long Sheath, Universal Emergency Brake Cable Repair Kit
https://a.co/d/jiJrO0C
There were a few hurdles to clear and I figured I'd write it up in case anyone else has to do the same. This only applies if you still have the Cobalt parking brake handle and the small cable with the adjuster nut that goes in the handle.
Additional parts needed:
4x M10 washer
2x M10 nylok nut
I started at the caliper. Remove the inner cable from the sheath, and remove the nylok nut that comes with the cables.
I found that the nuts that came with the kit were terrible quality, gouging the threads on the sheath. So I got new ones and ran over the damaged threads with an M10x1.25 thread cutting die to smooth it out.
Assemble at the caliper as seen in the picture. Getting a wrench or socket on the nut is impossible even with the wheel off, so I just jammed a large screwdriver against the nut to hold it while turning the sheath with an adjustable wrench.
Then put the inner cable back in.
42700
Fish the cables between the tunnel and the rear firewall (I went over the front of the subframe and over the brake line) with plenty of extra length to work with.
Remove the parking brake handle assembly.
Remove the aluminum barrel-looking nut assembly from the kit's L bracket and put them in the parking brake handle assembly like the picture below.
The tube-ish spacers on the left go over the sheath inside the barrel nut, but don't try to hold them in without the cable or you might drop them in the open end of the tunnel like me and spend an hour trying to fish them out.....
Then remove the Cobalt's tension balancer bracket (red X in photo) from the small handle cable (I used a Dremel cutoff wheel).
42702
Use a 5/16" drill bit to drill enlarge the threaded center hole of the brass block with 4 set screws (circled in yellow below).
This is where the handle cable will go.
Then put the sheath+cables through the barrel nuts and the inner cables through the brass block, tightening set screws to hold the cables in place temporarily.
Pull the handle cable through the brass block and into the handle, replacing its adjuster nut.
Tighten the aluminum barrel nut assembly. I moved it rearward as much as possible to leave lots of space forward of the bracket for adjustment.
Re-mount the handle assembly on the tunnel cap.
Loosen the brass block set screws and pull all the slack out of the cables.
Tighten the set screws, give the handle a yank, then loosen the set screws and re-tighten the cables.
42703
There is a lot of extra length between the caliper and firewall for this length of cable.
If I were to re-order these, I would try to find some that had a sheath that was 2 or 3 feet shorter.
Barring some reason to redo this with shorter cables, I'm just going to route the excess in a wide arc under the subframe.
Hellproof
Thanks for the write up. This is basically what I did with my install as well. The nut was was a pain in the butt to tighten on the caliper too.
Once I had the sheath installed in the calipers, fastened to the subframe, and routed through the firewall, I pulled the cable out of the sheath, then cut the sheath down (carefully) with a cutting wheel just short enough so it fit into the connectors at the backside of the handle. Then i pushed the cable back through the sheath and finished fastening it at the block, then cut the excess cable, etc etc. They sell them this long so it's universal and long enough for many applications. I don't think I even found one shorter than this that had all of the accessories.
ah.b.normal
On a tiny side note. Twisted steel cable ends tend to fray and unravel. (and when encountered really hurt!) In the bike biz we used little bits of aluminum tubing(ferrules) to crimp on the ends. Others have used solder and a third style is one or two layers of heat shrink tubing. Heat shrink is probably the fastest, cheapest and easiest.
You can pick up cable end ferrules at a bicycle shop.
Edit: Not big enough for parking brake cables, but will usually work on throttle cables.
Can you not cut the outer sheaths to length? Looks like the ends are unfinished and should be able to cut them down with a cut-off wheel.
RGSkid70
I can confirm that this kit works fine and is $20-30 less than the SS cables from Rock Auto. Instead of cutting off the tension balancer like neodied did, I simply cut the set screw block in half.
Also the cable sheath is sturdy enough that you don't really need the aluminum tubes from the donor.
RGSkid70
It's much easier to tighten the nylock nut at the caliper, using a deep socket, if you remove the top guide pin.
Grayson
4x M10 washer
2x M10 nylok nut
How did you end up routing your cable? About to do this for my car. It seems that you can trim this cable and sheath to size according to the amazon description. Hence the "universal" label.
neodied
My first install ran the right side cable under the subframe on the left first, then under the rear beam of the subframe to cross over to the right side and vice versa for the other cable. Used self-tapping screws and the rubber+sheet metal cable holder clamps attached to the under side of the subframe. I do not recommend copying that layout. It worked fine, but cutting the sheath as mentioned by hellproof and gtstorey would be far better.
Can't take pictures since my powertrain is out and the subframe + cables are removed. But for re-installation I will definitely cut the sheaths and run them the more logical way, right cable running under the right side of subframe to the right caliper.
Adam's pics of the parking brake is here. I found that I couldn't reach the parking brake if it is too close to the rear firewall, so I moved mine forward.
I wanted to reduce the number of bends, and tightness of the bends, in the parking brake cables, so I routed them thru the middle of the oil pan.
