Dominicnicklyn
Yes, I was thinking about this while laying in bed last night.This sounds like some of the issues I was having. The solution to my goblin's issues was
1. poor connection on the connectors under the fusebox, (reseating the connectors fixed this)
2. bad data connector at the power steering (bought a connector from an auto recycle yard, soldered it on)
3. replaced the power steering unit with used one.
I also cleaned every ground wire and retorqued all 3 of my grounding points, which have a bunch of ground wires on each one.
When your data is flowing enough to move the throttle butterfly, I wonder if jumping the starter motor would allow it to run. On my LSJ, I ran the purple starter wire into the cabin, so I could connect it to accessory 12V power, and jump the starter quickly, while in traffic. I had to do this for about 6 months, as it took that long for me to debug my data issues.
I'm starting to belive that I solved the original issue and now I have a bad ECM ground. I only lose coms with the ECM atm.
I'll check the fuse block plugs, but I've already set them in 3 different times believing they weren't making good contact. (Had to jb weld some plastics due to over tightening them)
I've done all of your solutions above. Even swaped ecm/bcm/ignition from another same model lsj.
I'll dive deeper when I get home from work.
