PyroGuy923
Sure does. Thanks.Look for G85 on your trunk plate to verify.
Don't forget to grab your e-brake cables, e-brake tubes and e-brake handle assembly if you are going with DFG's e-brake solution. I noticed your cables were still there. I didn't know I had to keep the tubes or cables when I stripped my donor, so I had to source them again!Got the rest of the donor body stripped over the weekend. Just have the dash left.
Did you buy the little plastic tips some where, mine fell apart when I took them outDon't forget to grab your e-brake cables, e-brake tubes and e-brake handle assembly if you are going with DFG's e-brake solution. I noticed your cables were still there. I didn't know I had to keep the tubes or cables when I stripped my donor, so I had to source them again!
I went to pick-and-pull to get another set and tips were fine. I doubt if you can get the tips by themselves, unless you try pick-and-pull.Did you buy the little plastic tips some where, mine fell apart when I took them out
Got them when I stripped the rear. Thanks.Don't forget to grab your e-brake cables, e-brake tubes and e-brake handle assembly if you are going with DFG's e-brake solution. I noticed your cables were still there. I didn't know I had to keep the tubes or cables when I stripped my donor, so I had to source them again!
Thanks.M4 X 0.7
Not sure. Didn't see it in the order or in the email. Will post when I get confirmation.You are chassis number 208?
Timing chain tensioner is a common Ecotec failure. A new tensioner has a bolt head that bulges out, the old stock one has a flat head.This waiting game is going to kill me. I should have ordered my chassis weeks ago.
What maintenance items do you recommend I do before assembly? Donor has 126k on it.
I know the timing chain guide bolt is cheap insurance.
I'm confused. Is this all I need?Timing chain tensioner is a common Ecotec failure. A new tensioner has a bolt head that bulges out, the old stock one has a flat head.
YeahI'm confused. Is this all I need?
https://www.dormanproducts.com/p-86802-917-954.aspx
