Jareth
What I did was just use two labels one on engine and one on connector, 1 to 1, 2 to 2, 3 to 3, …etc
r3drckt
When you log in, on the right side look for “diagrams” and then “components” and you will see the list of component names and where they are located.
You can use this information along side the “Connectors,” “Connector Views,” and “Harness” diagrams to figure out what is what.
I will add that the harness diagram for the engine doesn’t show the LSJ for whatever reason, but it may hall none the less as the ecotecs generally placed things in similar locations.
Sluggonaut
Same here. If I knew what it was, I labeled it as such. If I didn't know, I either guessed or numbered it. As long as you have the same label on both sides you can plug it back in where it belongs.
