Understood, thank youAnd by bend, I mean a dedicated section bent at an angle so the majority of the upright is still vertical, just offset in.
Is this an official DF issued drawing? It looks totally legit.OR, make rigid uprights that form an X (blue) that align with the existing mounts (red). Then connect the wing mounts to the upright mounts with wire/turnbuckles or threaded rods (green) to make it stiff enough.
I have. I drilled into my NRG wing to bring the mounts closer together. I put rivnuts in it, lathered in epoxy to give me a little more of a comfort factor. It's been up to 100mph multiple times. I'm not concerned.Question for the masses;
I found an amazing deal on a carbon fiber spoiler down the street from me but the mounting holes are only 22” apart. The uprights from DF are about 26.5” apart and with the 90° bracket make it about 24”-25”.
Has anyone drilled into carbon fiber to mount a wing? I’m not sure how thick it is but my thought was utilizing rivnuts if I can get them to grab (worried about the strength of that) or getting a longer bolt and using spacers to make up the difference.
Problem is that it won't give you any warning when it fails. Good chance it will be there 1 minute, gone the next.I have. I drilled into my NRG wing to bring the mounts closer together. I put rivnuts in it, lathered in epoxy to give me a little more of a comfort factor. It's been up to 100mph multiple times. I'm not concerned.
Be nice on my thread!Is this an official DF issued drawing? It looks totally legit.
I thought of epoxy too, with my skepticism and at least one person saying it was unsafe, I will err on the side of caution.I have. I drilled into my NRG wing to bring the mounts closer together. I put rivnuts in it, lathered in epoxy to give me a little more of a comfort factor. It's been up to 100mph multiple times. I'm not concerned.
I would have though so too, but it definitely didn't look like itIt’s probably inserts imbedded in the carbon. No way no how would I trust threads in carbon fiber unless it was extremely thick.
