V1 2006 LSJ ABS Wire
Torchandregdoc
I think there is a wire that triggers the fog lights and they have a decent relay and fuse. I want to say purple up by the column. It's just a momentary switch that triggers on and then triggers off. It will turn off when the car is shut off, which is a little problematic, but has worked for 5 years.
It also changes when swapping from low to high beam or the opposite?
Fixed. It was a broken wire between the power and the gages. I need to still clean the grounds well to see if that helps.
I do know that the BCM plug had battery voltage going across it, so it's not there that the drop is occurring.
