phantom3277
Member
- phantom3277 Member
Hello,
I bought a 2006 cobalt ss 2L LSJ for my donor, which original drove fine, but would stall on idle.
I’m going to provide as much info as possible as I feel like I’ve done a fair bit of due diligence on this issue(s).
ZZP tuned ECU
2.8 Pulley
Donor idle when received (drove fine):
drive.google.com
Driving donor back went into limp mode for 5 minutes with P2138 code. APP1 and 2 Voltage discrepancy.
During Testing some electrical changes, the timing chain became quite loud (later found broken guide and broken primary tensioner):
drive.google.com
Replaced the Pedal and got no change. During testing the idle got worse, with the timing chain visibly loud and the idle getting worse I didn’t want to risk it and stopped testing. Decided to strip the donor and fix in the process.
During the build process, I:
- Replaced throttle body
- Replaced MAF
- Replaced Oil
- Replaced Primary Tensioner and Broken Guide
- Ran 6 new wires from ECM to pedal jumper
- Tested a different Pedal Jumper
When I started the car (now open headers by the way) the idle still was bad (up to before the goblin side of things I have a pretty detailed log of what I did in the attached files). I actually replaced the throttle body at this point and I regained pedal control during engine operation strangely (lost that right before stripping), and the idle did better than the other throttle body, but still was idle hunting and sucked:
drive.google.com
Here’s the original throttle body. You can hear even after shutting it off it shutters due to the throttle body valve oscillating so much during idle and doing it a time or more before it dies:
drive.google.com
Here’s my thoughts:
- I need to replace the entire timing chain system and balance shaft system. Do you think it skipped a gear? Could this be the issue causing such a rough idle? FYI sadly so not have photos of chain at TDC, but they seemed approx 10 and 2 like the cloyes video said for the intake/exhaust marking.
- Directly wire the APP2 Sensor plug to the ECM with new wires. Maybe this part was damaged?
- The check engine light is still on, but no power to OBD2 plug so I need to fix that before I can confirm the code is the same (assuming it is or a similar). I think maybe I messed up the low speed cluster green wires for it. I need to dig into this as well.
- Bad tune or messed up ECU? It did get worse when I ran the one wiring test and originally thought I screwed it up more (see diagnostic log), but I’ve come to think it might’ve been the timing chain’s poor coincidence giving out. ZZP’s info on the tune matches up with what I see on the engine unless I overlooked something, but they also said my issue is always the throttle body, pedal, or wires. And I’ve tried all three. My other pedal was in rough shape that I tried (exposed to some water/elements), but it didn’t seem to change the result and appeared functional to the same degree as the other.
- Vacuum leak? I’ve attached a bunch of photos in case there’s something wrong, the previous owner had some interesting routing and perception on stuff in the not so good way, so maybe something is there. But the error code seems to point electrically?
Any and all help would be appreciated. I’m not unfamiliar to cars, but powertrain and electrical is not my primary knowledge in automotive (suspension and vehicle dynamics) and I’m still learning in these other areas.
ZZP tuned ECU
2.8 Pulley
Donor idle before getting more violent
drive.google.com
Timing Chain Noise and Idle
drive.google.com
- Replaced MAF
- Replaced Oil
New Throttle Body Test
drive.google.com
Poor Idle (Initial Goblin Startup)
drive.google.com
Here’s my thoughts:
