- Robinjo Goblin Guru
Asking $19k (OBO). Located in 35801 Huntsville, AL. If this post is up, it's still for sale.
I’m selling my 2022 DF Goblin kit car, it has about 20k miles on the car powered by 2006 Chevrolet Cobalt SS 2.0L supercharged LSJ engine and a 5-speed 3.82 limited slip differential. I am the original owner and builder of the vehicle, chassis #405. The engine is on a 2.8” pulley and makes 245-255 wheel horsepower and weights about 1,550-1,600 pounds. Along with the smaller pulley, the engine has the ZZP dual pass coolant system, ZZP phenolic spacer and a ZZP shorty header mated to the DF 2.5” exhaust system. The supercharger has recently been serviced with new needle bearings, polishing supercharger internal body, new ZZP coupler and fresh GM supercharger oil. The transmission has been serviced in the last 5,000 miles with new synchronizers and bearings. The transmission also has an ZZP upgraded LSJ clutch, ZZP upgraded LSJ throw-out bearing and ZZP lightweight flywheel. Interior has stock cobalt SS seat bit will come with the metal mounts for racing seats, DF forum group-buy shifter setup, digital boost gage and AEM AFR gage. The car has a front splitter setup, dual intercooler heat exchangers both with fans and brake proportioning valve. The wheels tires are 17x8 +35 Konig Illusions black with red accents on 225-45R17 Azenis RT615K+ tires. Suspension is the BC Upgraded front and rear setup, brakes are the upgraded parking brake setup with an under-hood proportioning valve setup to adjust front/rear brake bias, hubs are redrilled by DF to 5x114.5mm for better wheel selection. Steering has the DF rack limiter kit installed. Also has a Shade Idea net top to bloc sunlight but not airflow. Chassis is the old standard version that is 4” shorter, with full cage. I have the DF rear wing uprights and carbon rear spoiler installed. For more information, go to the DF Kit Car website on what these are.
I have amassed many extra items, including items that were going to be winter projects.
I have a set of Cobra R wheels (17x9 unknown offset) with worn out 255-40R17 tires, a 75-80% left set of 225-45R17 Falken Azenis RT615K+ and a set of 225-45R17 Falken Azenis RT660.
Other extra include a set of 16” wheels with tires used for flat towing the vehicle
Spare MAF, thermostat, and other miscellaneous parts
previously mention racing bucket mounts
rear plexiglass engine shield
intercooler duct kit with pusher fan
3.0” ZZP pulley (in case you want to go slower)
Siemens 60# injectors with ZZP harness, new O-rings and new insulators
Caster and Camber tools
Plug in ready LED lights with halo rings and plug in ready DF lights. Spare set of DF turn signal mirrors.
Car Cover
HP Tuner MPCV 2+ with laptop. You will need you own HPT credits which are about $100.
Tow kit will not be coming with the car
Car Cover
