V1 A/C refrigerant
I started watching the first few videos for stripping the donor. Should I have the A/C refrigerant removed prior starting?
Murcielago311
This should help. Link
I had mine drained at a local tire place. They charged me $50 to do it, which I thought was ridiculous, but I called other places and they all wanted to charge for a full AC service to do it.
KSLunsfo
Sheesh.... and one more reason people will just crack a line and walk away... This problem goes away of course if your car was hit in the front and suffered the appropriate damage.
Thanks guys. Had a local guy do it for free this morning (of course he got the refrigerant). Not so much a tree hugger, but I try to do my part. :)
Nice guy. I had a hard time finding someone to pay to remove my refrigerant. They wanted $140 at some shops... but I found one that would do it for $20.
I don't understand why they allow the sale of canned air, it is the same gas used in car A/C units.
The sole purpose of canned air is to vent 1,1,1,2-tetrafluoroethane into the atmosphere so you can dust things off.
https://www.winzer.com/UserFiles/documents/891_7039_7.pdf
I think there were laws that did not allow you to vent R-12 into the atmosphere, I wonder if there are laws against an individual venting R-134 a from a car instead of from canned air?
It would be nice to know if it is acceptable by EPA for our builders to just vent their systems.
Tinkles
There are. It has been 10+ years since I got my certification. But as I remember and release of refrigerant gasses into the atmosphere is punishable by prison time and a very hefty fine under the Clean Air Act. I want to say it is sections 608 and 609 of the Clean Air Act where everything is defined.
I have searched all over the internet trying find the actual R-134a laws. I read through through the EPA sections that refer to 1,1,1,2-Tetrafluoroethane.
Everything I find is about it's safe handling.
While reading through the EPA PDF I found that 1,1,1,2-Tetrafluoroethane is vented to the atmosphere in most of is uses.
I have a feeling that 100% of the R-134a that they sale at auto part store, Walmarts and gas stations is eventually vented into the atmosphere.
This is the description they give.
1,1,1,2-Tetrafluoroethane is a hydrofluorocarbon and haloalkane refrigerant with thermodynamic properties similar to R-12 but with insignificant ozone depletion potential and a significantly lower global warming potential.
Other uses include plastic foam blowing, as a cleaning solvent, a propellant for the delivery of pharmaceuticals (e.g. bronchodilators), wine cork removers, gas dusters, such as Dust-Off, and in air driers for removing the moisture from compressed air. 1,1,1,2-Tetrafluoroethane has also been used to cool computers in some overclocking attempts. It is the refrigerant used in plumbing pipe freeze kits. It is also commonly used as a propellant for airsoft airguns. The gas is often mixed with a silicone-based lubricant.
Until I see something that says it's okay to dump our R-134a I'm not going tell anybody to do it. But it seems like it's common practice to vent 1,1,1,2-Tetrafluoroethane into the air everyday.
