Yeah, I'm thinking that's a much better way to go. They are so much more efficient and don't have to dissipate all that power. Here is a link to more available. Too many choices!
That is all correct but the biggest issue it getting the input voltage (13.8v) down to 3.3v while passing .270A. So there is 2.8W of power that has to be used or dissipated as heat. That's terribly inefficient.What's the forward voltage on those LEDs? 2.9V.
R = E/I
(3.3 - 2.9)/.27
1.5 ohms
P=IE
P=.27 * (3.3 - 2.9)
P = .108W
If my math is correct and thinking along the same lines as Brad.
This is calculating the power dissipation for the current limiting resistor, not the entire circuit. Even at a 1/4w, I'll bet it still gets a bit warm dissipating .108w.P=IE
P=.27 * (3.3 - 2.9)
P = .108W
Net result of my testing - the linear regulator worked but got warmer than I liked for being placed inside the cluster as ctuinstra previously found. I ended up using a cheap chinese buck converter that drops the battery voltage to 3.3 volts and then 1.5 ohms worth of resistors. The buck converter is rated at 3 amps (way overkill) and does not generate any heat.
I only had to cut one trace and trim some of the plastic on the back cover of the cluster to fit the buck converter. The lighting looks amazing and was totally worth the effort.
You are not wrong, they look way better in person. I can't believe the improvement. Thanks for doing the legwork on this one!Love it! I wish I would have thought of the buck converter when doing mine. Eh, either way works, yours is easier to do.
Sure does put the old filament bulbs to shame!
It's hard to get a good picture of how they really look. So much better in person.
Did you use the pad that corresponds to pin 8 on the cluster connector for you voltage converter input?
Also curious to know what trace(s) get modified. Do you have a schematic for the cluster board?
I need this guide to follow.**I did not take pictures of what I did, so I stole a picture from ctuinstra to mark up what I did. This picture is only for reference - please ignore the wires and resistor. Because there was a wire in the way of one of the traces, I represented the trace by the yellow lines.**
Yeah exactly, I would like to start at zero with the new engine/trans.I'd like to least turn it back to when we finished the car. Missouri just passed a new law and now the Motor Vehicle Safety Inspections are only required on vehicles over 149,999 miles. I don't want to have to take it in to get it inspected any sooner than I have to.
