Waterdriver
- Waterdriver Goblin Guru
I saw in Silverback's post that the Kirkey mounts wouldn't with the sliders he's using. Unless I missed the post your referring to.
Running F: 15x7 R: 15x8, p205/p235Looking great! Wheel and tire size?
There's a posted list of what people are installing on their cars. http://dfkitcar.com/forum/index.php?threads/wheels-tires-and-seats-list.521/
I was thinking kind of the same thing. Its rubbing, just barely.have you tried loosening those and pushing and or pulling wheel to see if rotor moves away from the ball joint.
Worked the tail light wiring and mounting.
Drew up some simple wiring clips and printed them out.
And here on the car to help keep things in place.
I am using both O2 sensors. The DF exhaust had an O2 bung in it, so I thought I'd use it.Curious are you using both o2 sensors?
Found out some bad news today. A leaking laminova tube or seal. Or is it a cracked manifold.
Went into the garage today, after testing the intercooler yesterday, the reservoir tank was only a quarter full. (Instead of half full where I topped it off)
Filled it back to half full and started it up. Fine at first and then revved it a little and all kinds of steam and small amounts of fluid coming out the exhaust.
Checked the oil and OK there.
Drained the intercooler system and ran it a little while until it cleared out.
Has anyone removed the supercharger and manifold while the engine is still in the chassis? It looks to be doable, just not comfortable.
On a side note, the intercooler and tank was holding pretty close to a full gallon of coolant.
Good news for the day, my brother and his wife made a cool birthday present.
