V1 ccgillett's Track Goblin - '08 SS/TC
ccgillett
Mounted up the intercooler, which turbed out to be a lot more fiddly than I had expected, glad that's done.
Previously I had mocked up fittings for the turbo plumbing, and I started to connect things up today. There's an almost-U shaped fitting that helps to route the charge air into the engine. When I position that, and make sure it's "all the way up" on the flange on the engine side the fitting rubs against the fuel take and seems constricted - almost folded. Is this normal? It doesn't seem correct, and since this is an older kit it's entirely possible that I have an incorrect part.
52284
52286
52287
52283
ccgillett
You have to cut that u-shaped coupler on the throttlebody side, cut it down a little bit at a time until it just clears the gas tank. I've got less than 1/4" clearance between the tank and that coupler.
Great, that's what I was thinking. With the neoprene couplers, can I just use shop scissors to trim any of them to fit? I am gonna have a similar issue on the other side of the intercooler with the couplers and piping coming from the turbo. Sorry for the newb question, I haven't done plumbing like this before.
Traé
I usually use a set of tin snips to cut stuff like that and the coolant hoses. Beefy scissors would probably work, or small cuts with a set of side cuts but might end up not as clean.
ccgillett
Sounds good, thank you! I assume I can cut the metal pipes to fit as needed as well, correct? I may need to trim the connecting pipe between the intercooler and the turbo outlet down a couple inches.
Traé
Ooo, I’m not sure about that. I would see what Joe says about his tubing. I have an SC so didn’t have this issue, sorry!
ccgillett
How's this coming @ccgillett ?
It's been a weird few months. I got the turbo plumbed and started rough-in on the plumbing the A2W intercooler. I was then sidelined for a medical issue that was ultimately resolved surgically in late September. I was blocked from lifting stuff more than 5 pounds or doing heavy pushing/pulling for a few weeks, but that's been withdrawn now so I can get back to work.
I'm not happy with the air intake routing and have been looking at other build photos. I think I will re-route mine and use a snorkel of some sort to direct airflow as I'm worried about the stock routing interfering with the pax-side suspension.
"What's this box of parts" is always a scary thing to hear, and we found a box with a bunch of hardware in it buried in a box full of old donor parts. This hardware is what was originally sourced for stuff like fuse box mounting, etc. I'll take off my home-brew bits and use the supplied hardware.
There's also an issue with front tie-rods and I seem to have 3 or 4 different sizes/part numbers. Goal for this weekend is to (a) get the front brakes and hubs installed so I can fill the hydraulics reservoir and bleed the brakes; (b) get the car to start with the induction plumbing done; (c) shoot a quick video about my tie rod issues so I can whine for more help; (d) try to not get distracted by Adam selling shop cars :cool:
54297
54298
54300
54299
ccgillett
Aaaaaand we're back! After a a lengthy period of unwellness including an unrelated surgery, I now have a new left shoulder and am now pain-free, what a lifesaver! Doc removed all my restrictions a month ago so I can finally get back to this car. If you've got a bad shoulder due to arthritis and your doc says "shoulder replacement surgery" you should do it. Don't be like me and endure 5 years of intense pain needlessly.
When I got the car it was slapped together enough that it could roll on its own, but the uprights were assembled incorrectly (and with Grade 5 hardware) and the car had the original (thinner) control arms that were subsequently recalled/replaced by DF. After a false start involving wrong tie rod ends last year it was time to do this correctly.
Over the weekend I cleaned up everything, got the shop back in order, and purchased new Grade 8 hardware. I correctly assembled the front uprights and got them on the car. Then I installed the brand new wheel hubs and then then new front brakes with Brembo pads. I managed to get 3 of the 4 brake line clips to rivet into the uprights successfully, one self-destructed (I might have forgotten to open up that one with 1/4" bit). I have many spare rivets and several coated brake line clamps, so I'll just sub in one of those for the broken piece.
With that done I verified brake line connectivity to all 4 corners, checking out the rear junction connector as well the master cylinder connectivity, etc. I reviewed everything for tightness, correct fit, retaining clips in place, etc. Then I filled the brake reservoir, and after many brake pedal pumps was able to get fluid flowing to all 4 corners. I still have a very spongy pedal and no caliper movement, but I haven't done a proper 2-man bleed process yet so presumably that will fix it.
When I bleed the clutch will the pedal begin to return on its own when the bleeding process is finished?
I have wheel spacers to install on all 4 corners to support my "big slicks" square setup. I need to cut down the lugs on the hubs, so I only need to make 20 perfect cuts. Nervous about that, but it's on deck to start tonight.
A few photos....
My understanding/recollection is that SS/TC clutch pedals don't have much of a return spring? I think that's only a concern before the pedal is bled. After it's bled the hydraulic pressure should return the pedal for you.
ccgillett
That is my assumption as well, thanks for confirming.
duthehustle93
Do you have any additional info on the recalled control arms? I got replacement steering arms from DF, and asked if there's any additional recalls, and they told me that it's just the steering arms.
Correct, it'll return once it's bled. I used a cheapo harbor freight vacuum bleeder to get it started, then did a manual bleed from there. It wasn't bad at all.
ccgillett
I may have used the wrong terminology here. There's only one recall from DF that I know about, and it's for the part circled in the picture below (not the upright, but the attached arm). I've referred to that as a control arm, if that's the wrong name then I apology for being dumb and confusing :D
duthehustle93
lol, all good! Yep, that's the steering arm recall. I was freaking out thinking I'd have to pull my front suspension back apart right after getting my alignment dialed in.
