Clip for aluminum clutch 90 on ss/tc transmission
Lando217
Lando217
Hey guys I am looking for the clip that holds on the bottom part of this 90 and seeing if anyone has one laying around? It’s hard to find online and the ones I do find are for the rest of the clutch line and I I think don’t work. I Removed it cause I installed a new clutch and throw out bearing. I’ve tried to use the other clips from the cluch line and it must be different cause I’ve tried for hours with no results. Any help or advise would be great thanks!
Wes
Are you trying to put it on after inserting the line? IIRC the clips go into the connector and the line gets inserted and locks in.
Makes sure you don't put the clip the wrong way, look at the clip on the clutch master cylinder and orient it the same way competed to the slot.
ncgoblin
Ncgoblin I am needing help on the other end of that 90 where it connects to the transmission. Or does the clip go the same way on the other side? Cause this right here would explain a lot on why I couldn’t make it work lol inserting it the wrong way.
Same way on the other end I believe I’m between the slits not through them. If it’s correct it will clip on with low pressure. Also make sure the rubber seal is installed first.
