Trail_Creeper
- Trail_Creeper Well-Known Member
So I had the car running, found out the alternator was dead. Yesterday changed the alternator and put in a junkyard lower fuse box to hold the fuse panel and ECU (mine was missing)... now it won't crank.
Key in "on" position and everything comes on (stereo, horn, blinkers, etc). But the car won't crank and OBD-II port wont read.
Went out this morning and re-seated all the BCM and ECU plugs same issue. Did some searching on the Cobalt forums and found some things to check out after work like grounds. Since you all have taken these apart and had your own sets of issues I figured I'd ask here.
