Some of you may have seen in the Midwest Meet up thread my transmission decided it needed a few more holes in it, 55 minutes from the meet up spot. I felt the car shutter for a split second, felt similar to a miss fire but nothing popped up on the dash. Happened again a mile or so later, looked in my mirrors and saw smoke billowing out of the back of the engine. Still no oil pressure light or check engine, got off at the next exit, as soon as I slowed down I could smell the transmission fluid, car didn't want to go into 1st or 2nd. State farm's road side assistance cost me like 30 cents a month and covered the whole 3 hour tow home.
Pulled the transmission out. Dropped the sub frame, lowered the engine and transmission down and slid the transmission out, this way worked really well.
Tore the transmission apart, the internet isnt kidding when they say you need some specific tools to pull the transmission apart, I didnt have any gear pullers that would work so I went with the next best thing, I cut the gears off that were pressed on.with a cut off wheel on my grinder...
Saved the most important part. Everything else is in the trash!
The transmission with the LSD was one I bought off a guy on marketplace for practically nothing, it has always had a really bad gear whine on deceleration. I didn't want to have that transmission rebuilt because the dingus that pulled it off forgot a bolt and broke off one of the mounting tabs. Most likely what I'll end up doing is if DF still has any of those F35's available I'll buy one of those and send this quaife LSD to them to install in a zero mile F35.
Any way, threw the transmission I had from the donor in today, while I have the subframe off going to clean up a few other things.
