Mayor West
- Mayor West Goblin Guru
Sup,
I'm doing a general overhaul/cleaning of most of the engine's seals/gaskets/etc to keep myself busy while I save up for the kid components, the head's off and I'm deep cleaning everything. I need a lot of gaskets/seals.
I have a few questions:
I'm not planning on doing any engine modifications aside from a tune, so I'm not building anything up while I'm in there to save money.
- Which bolts are TTY?
- I've seen head bolts and flywheel bolts but I'm not 100% certain those are it or which cam bolts are TTY.
- Where's the best place to get all the gaskets and seals?
- I've found a lot of them on ZZP but not everything.
- Hoping GM is a last resort...
- What's the best quality, but not super high-priced timing chain set?
- ZZP is about $300 and I'd prefer to spend a lot less than that if I can help it.
- The orientation of the two balance shafts, is there info on that?
- When I removed them I wasn't thinking about re-installation...
