Enhanced Inspection Pennsylvania ACME Car Company New Cumberland, PA 17070 717-774-9450
Again, without something to go with this, it's not of much use since they obviously are looking for yes answers on some and no on others. For example, I would say they are looking for NO, NO and YES under "Tires/Wheels" section.
Doug Rostad
According to John (please , everyone call John 717-774-9450 and ask)
Kit cars in Pennsylvania MUST have:
13" ROUND steering Wheel
DOT AS1 Windshield / with the D.O.T. AS1 etching on it
Head lights and Tail lights with D.O.T. markings on them
Fenders over all tires , not extending over the tire tread
Front , yes I said front sway bar
Collapsible steering column
Brake light indicator
front and rear side marker lights including reflectors
Battery, Isolated from passenger compartment
Defroster <-- just a battery operated defroster
Electric windshield wiper with a park feature with operating washer fluid
front and rear bumpers 12" to 20" from the ground
engine covered so there is no way the engine can be touched
no holes in the floor
Here is what John sent me in an e-mail:
  • EQUIPMENT CRITERIA
    SPL. CONSTRUCTION
    Shocks present
    Sway/stabilizer bar
    Energy absorbing steering column
    Steering wheel min. 13” dia.
    Steering linkage components secured
    Service brake acts on all wheels
    Brake lining & fluids meet SAE J998
    Brake lines approved for use as brake line
    Parking brake has separate actuating system
    Parking brake can hold vehicle on 20 degree slope in neutral
    Tires cannot be marked “not for highway use” or unsafe
    Non-pneumatic tires prohibited
    2 headlamp system, type II construction
    4 headlamp system, 2 type II/2 type I construction
    Headlamps show correct SAE designation
    Low beam minimum 7,500 candle power
    High beam, less than 10,000 candle power
    Total CP 150,000 incl. aux. lights
    Headlamps must be able to be aimed/adjusted
    Dimmer switch
    High beam indicator
    2 stop lamps
  • 47707
    Reflectors (front & rear)
    Parking lamps 2 fronr/2 rear
    Tail lamps 2 min.
    Turn signals front & rear
    Turn signal flashes 60-120 per minute
    Hazard warning lights
    Rear lamps work with headlamps
    Required lamps proper color
    Back up lamps
    License plate light visible 50”
    Warning light on dash to indicate brake failure
    Battery securely fastened
    Battery not in passenger compartment
    Windshield present
    Safety glass all windows
    Windshield AS-1
    Other windows AS1,2,10,11
    Rear view mirror, at least 1
    No rear window louvers
    Windshield defroster
    Windshield washers
    Windshield wipers
    Wipers return to rest position
    Wiper control conveniently located to driver
    Accelerator pedal secure
    Gas cap present & secure
    47708
    Speedometer (mph/kph)
    Odometer ( miles or kilometer )
    Exhaust (shielded from being touched )
    Horn
    Fenders all wheels
    Hood covering engine
    Hood securely fastened
    Bumpers required front & rear
    Bumper height (horiz. Bar 12” to 20” above ground)
    Doors latch securely if present
    Frame no rust no damage steel or equivalent
    Floor secure, no holes
    Seats securely fastened
    Safety belts
    Body securely mounted to frame
    Engine must be fully covered to avoid touching
So how are you going to cover the engine so it can't be touched?
Where is ACME sourcing their windshields? And can you make one of those work.
I sort of get the feeling that this inspector is harder on vehicles he doesn't sale.
Goblinfanclub1234
I spent a couple thousand dollars fighting Colorado to get mine legal and they agreed 14 months after I used Montana. Now they are currently denying a follow DF Goblin owner in Denver. Hate these people.
Metal Mech
That list is a little confusing to me. It doesn't have pass/fail requirements laid out.
Nope. You try to follow the list. Then when the PenDOT inspector gets a hold of the photos he questions everything. One of the PA Goblins went round and round with an inspector over if his front fenders were far enough forward.
LLBenJ
I'm sorry, but not surprised, you are dealing with this brother. I recommend you take the Montana route and join one of the last free states in the west and get your car on the road. Once it's a registered vehicle, you may have other options.
Fortis Fortuna Adiuvat
