AMCAMX1969
Active Member
- AMCAMX1969 Active Member
I've been searching through the forum for the ground clearance to the bottom of the frame and the numbers are all over the place (most likely due to tire size and/or coil over settings) I've seen everywhere from 3" to 7" from the bottom of the radiator support to the ground.
With stock height tires (~25.5") what is a reasonable height?
