ccannx
- ccannx Goblin Guru
I'm just starting to get the handling sorted out on the car and the next noticeable drawback is power with my LSJ.
There are options out there like the TVS 1320 and porting the head, cams $$$$. Getting 350+ from the LSJ will require at least a stage 2 turbo according to ZZP sales convo we had. ZZP is out of stage 2 and not sure if I want to go the TVS route. A new LNF can be had for 2k : https://www.high-performance-engines.com/GM-2-0-Ecotec-Complete-engine-p/20lnf1.htm
I actually have a friend who lost a guide bolt and had a new one dropped in his Solstice he is offering his old LNF free with the turbo and all.
Just trying to figure out all involved with swapping one into the Goblin. Will it fit, frame differences, ECU/BCM compatibility/ upgrade needed, wiring harness compatibility ? Will the LNF bolt to my transmission ? Could I just pull the turbo bits off and use them on the LSJ.
Lots of questions time to start reading up.
