- Brocker Active Member
Just got a copart GTI that I'm planning to use for a V2. The car was seriously damaged on the passenger side but the engine and transmission appear to be fine. 74K miles on a 2015 GTI S. All airbags were deployed.
The engine started immediately upon receiving it Monday. It ran for about 10 seconds and quit. Suspect fuel starvation.
I cannot start the car since code P1609 (crash shut off) is activated which apparently disabled the low pressure fuel pump. The web tells me that HP tuners can't clear the code. Don't want to spend the money for HP credits for the car if it won't work. I have the MPVI3.
Should I attempt to add 12 volts to the fuel pump to see if the car will run that way?
I've disconnected the SRS module.
Do I need the SRS module in the kit car? If so I will have to get mine reset due to the crash which made the car a donor in the first place.
How will the module on the kit car be bypassed if we keep it?
Any help appreciated. Don't mind buying a VW specific bidirectional scanner if it will do the job. How about Ross Tech? I emailed them but got no answer (Veteran's Day?).
I know enough about electrical systems to know this is beyond me at my current level of expertise.
