I have been using the bellhousing spacer. Here are my current options:The air gap may be correct but if the F23 T/O bearing compresses the F35 pressure plate fingers further in it could contact the clutch hub? This is all speculation on my part as I Do Not have the pieces(even used) to compare clutch stack heights.
Are you using the bell housing spacer plate used on the F35? No "right answer", just for info.
There is also always a possibility the clutch hub/springs gave up? They can be real poop heads and not give 2 weeks notice.
The partial engagement is a similar feeling to an automatic car letting off the brake and rolling forward. I think im going to buy your same clutch setup and try it. Are you using a bellhousing spacer on your goblin?I should add, my setup is F23 + the original LSJ-F35 bellhousing spacer + South Bend Stage 3 clutch and PP + ZZP aluminum flywheel
I don't know that air gap or slave cylinder displacement or clutch stack heights explain partial-zero-full clutch engagement through the pedal travel.
Can you elaborate more on the partial engagement at zero pedal push?
I used na cobalt axles.Finally getting around to the rear suspension and hubs and I ran into an incompatibility issue. The hubs are too small to accept the axle splines.
The axles are 2000 Grand Am (30 spline).
The wheel hubs are purchased from DF Kit Car and are the 5x114.3 non-turbocharged option (33 spline).
I am getting lost in the sauce of should the 2000 have been compatible with the 2007 cobalt SS hubs? Did I need to swap to LNF hubs? Do I need to swap knuckle and LNF hubs? Do I need to swap to lower control arm, knuckle, and LNF hubs?
Should I have gotten the turbocharged DF Kit Car hub options?
Trying to figure out where I made a mistake, so I’m reaching out for help here.
I have the df 5x114.3 hubswhat knuckles and what hub paired with those?
Seems to do the Grand Am axle swap you need the LNF Hubs. Unless I am incorrect.Finally getting around to the rear suspension and hubs and I ran into an incompatibility issue. The hubs are too small to accept the axle splines.
LNF hubs only fit in LNF knuckles, non-LNF hubs only fit non-LNF hubs. LNF hubs will only take LNF half shafts with an F35 transmission, and I'm not an expert in the F23 swap but I think Grand Am half shafts only go with an F23 trans and LNF hubs in LNF knuckles.
With non-LNF hubs you can run all non-LNF Cobalt parts, no Grand Am parts needed. I believe brakes are knuckle specific as well but the only difference should be the caliper bracket adapter.
zzperformance.com
Base model manual trans Cobalt axles don't have an intermediate shaft, so yes, the set you linked should work.Yes, I have non-LNF knuckles and hubs. I also have the 30-spline Grand-Am axles that require the LNF knuckles and hubs. Ok, now I understand the issue and compatibilities.
Now that I am finally following, and since I seem to need it spelled out entirely, I want to rephrase what I'm hearing the solution to be: I need to buy NA cobalt R&L Axles plus the NA cobalt intermediate shaft (?) and these will fit in both the F23 transmission and the non-LNF (33 spline) hubs I have?
Here's a link to an axle set for a manual 2005-2010 cobalt 2.2L Can anyone confirm this is the part I need before I purchase? My quick research shows these have the 33 spline shaft that is compatible with my hubs.
The axle set linked above has one long axle (passenger) and one short (driver), so it would not require the intermediate shaft. That's one less part I'd have to locate and purchase, so I see it as a positive. Does anyone have an argument for why I should get the intermediate shaft and the set of two short axles?
Now we just need 4340 Grand Am axles. Won't hold my breath.Can't speak to compatibility, but if you are using 2.2 F23 axles I would probably upgrade to these.
ZZP 4340 Axles - 2.2/2.4 Ecotec
We are proud to introduce our new line of ZZPerformance 4340 axles. Built Stronger. Balanced Smoother. Engineered Smarter. ZZPerformance axles are designed from the ground up to outperform both OEM and aftermarket alternatives. Every detail, from material selection to surface finish is...zzperformance.com
I haven't had a chance to try em myself, but I already snapped some OEM ones before (albeit drag racing)
just to tie up loose ends, I installed these axles and that solved my issue.Can't speak to compatibility, but if you are using 2.2 F23 axles I would probably upgrade to these.
