V1 Helpful part numbers
Smokin' Goblin
I thought I would start a thread on helpful part numbers others may need, but too difficult to search. If you add to this, please add what doner you have or have it in your signature, so others know what they are looking at.
06 cobalt SS SC
LSJ 2.0 supercharged
MU3 Saab 5 speed
G85 limited slip
Oil filter acd PF458G
FF wix 33980
Spark plugs acd 41-106
Belt gates DK060702
Wheels
update
Forgestar F14 semi concave, matte black 17x9, backspace #10
Old-Vertex RTX 17x7.5 5-110 32p C65.1 satin black
34042809
Tires
update
Toyo R888r
front 245/40zr17
rear 275/40zr17
Old-245/40ZR17 BFG Gforce comp2 as
Seats
NRG innovations RSC-208L/R
Planted technology cobalt seat brackets
SB225DR and PA
with the cobalt brackets, these were a direct bolt in.
Belts
NRG 5 pt harness SBH-B6PCBK
Steering wheel
NRG short steering wheel hub SRK-177H
NRG quick release SRK-650BK
NRG wheel RST-024MB-R-Y
Part numbers ——-
Fuel tank Vent Rollover valve summit TNK-VVR
MOOG camber kit K90473
MOOG outer tie rods rear ES800030
Moog control arms RK620897 and 98
Duralast inner tie rod rear ES80445
Outer Tie rods ft 613.44063
Grom tail light Honda HOE2QMK-X001-Y001 (specific to mine)
Grom tail light blaster 14GROM_REV0A_PI2_SL (specific to mine)
Turn signal switch acd D6254E
Lumen headlights N218X-2-SP and CM
Mirrors cbr1000 HTTMT-MT324 black smoke
Steering shaft GM 15800140
Valve cover gaskets felpro VS50772R
Chain Tensioner ACD 12608580
Post cat o2 acd 25775833
Pre cat o2 denso 234-4066
ACD 213-968 or 12568234 Ho2s
Timing guide bolt dorman 917-954
Supercharger bypass solenoid ACD 1997244, STD U44001
Spal 12” puller fan main rad SPA30101522
Spal 7.5 pusher fan ic rad SPU-IX-30100393
Black diamond grip tape- used on floor
Exhaust collector gasket fel pro 61559
Park brake cable L or R 15875458
Raybestos pads EHT956H EHT1095H
Coolant hose Goodyear 63936- reservoir to engine ‘98 chevrolet truck part
Dayco rad hoses E72461 E72461
IC water pump acd 22718756 Or Bosch 392 022 002
Scotch vinyl mastic pads 2200- sticky back insulated “tape” to protect parts From sharp edges.
Brakes from DF
Ft is 09 base cobalt ft
Rear 09 solstice rear
I’ll edit as I get more
Since zzp and all other outlets I could find is out of the dual pass cooler, with a bunch of phone calls, come to find out, It can still be ordered from the dealer in their GM performance line. It will come up as “out of stock”, but it’s actually considered “order through manufacturer”. This means, you order it and they will send it to you. I got mine in less than a week. :cool:
part number Dual pass endplate 88958721
Aluminum lower control arms for TC models, GM part numbers
TravMac
Does anyone have good part numbers for the rod ends in the car? Found a good reference with some of the comparable company designs at the page below, but not sure what other folks are running as they are replaced (if you've replaced them).
Ball joint style rods ends or heim style rod ends? The parts you listed from the FK catalog are heim style. The 'stock' Goblin rod ends are ball joint style rod ends. Unless you have modified your steering arms (front) or knuckles (rear) to make them bolt-thru to mount heim style rod ends, you should start your search in RockAuto for the Cobalt parts.
Like these?
TravMac
Ha you got me - I shouldn't have said rod ends without specifying i mean the suspension arm connection joints for all the control arms. I think the best I've found are the loader slot designs which would be on that page as FK - KMX series, QA1 XMR series, and midwest control MXM series. But again, curious what other folks have replaced/run with
Suspension heims come in basically 3 flavors - cheapies (with a obvious pressed in piece on one side to retain the inner ball) - good (with a full machined surface on both side, usually have a Teflon liner between the inner ball and the body) - expensive (noticeably thicker body width, usually have a metallic surface between the inner ball and the body). The good type are the ones you want to install on a Goblin suspension, these are the type DF uses. Stay away from the cheapest, since the pressed piece can wiggle out over time and the inner ball will no longer be in full contact with the body - noisey and loose. The DF parts don't have any manufacturer part numbers on them, that I can see. You will have to order them based on the size - mount thread (think it's 5/8?) and mounting bolt diameter (5/8 too?) - someone else will have to confirm. But also know that there are LH and RH thread heim ends used in the suspension. Mine has both, some other builders have reported having only RH threads. This should be checked on the control arms before ordering.
Also, it was noted that non-ABS base model ~06 Malibu will fit a Goblin front and have no sensor that requires trimming. Be sure to check your lug measurements to make sure it fits what you have.
Moog 512287
53586
These fit the tie-rod brace that replaces the rack and pinion in the rear. Mine arrived last night and I checked them out. basically 4 for less than one of the official GM part numbers.
Amazon.com: Kozelo 4 Pcs Hex Head Screws Bolts - [M12-1.75x150] Carbon Steel Grade 10.9 Fully Threaded Hex Tap Metric Hexagon Head Machine Bolts Right Hand External Hex Drive, Black : Industrial & Scientific
Just to clarify, that thing is called "Toe Link Bar".(A bit of DF Goblin science I am quite grateful for!)
