CaptFrank2001
- CaptFrank2001 Goblin Guru
Plug in your weight & HP and it gives you a 1/4 ET estimate .... https://robrobinette.com/et.htm
My car seemed to hit an invisible brick wall at the drag strip in 3rd gear maybe a combination of aerodynamic drag and my insanely high IATs150-160s! on a 85 degree night pretty sure the car was pulling power to save the engine. only trapped 110 ish Unsure if the S/C guys have as much heat to deal with as far as IATs go. Recently installed a spal fan on the heat exhanger and re routed the cold air to grab cooler air. 12.4 is quick but is no hellcat. Im pretty sure ive seen NA goblins better this time. Long story short, street light to street light the goblin is quicker than most things on the road. However in a highway roll race setting there are a few things to sort out in my opinion. This is referring to a "stock" configured T/C goblin without the ducting.Any 1/4 mile calculator will give results of about 10.5-10.6 seconds at 126-128 mph for a 1600 lb 260 hp Goblin - if it hooks up. There are very few cars that make those times/speeds that are driven daily, so the correct answer 98.75% of the time is 'quicker than your [Mustang, Camero, Challenger, rice burner, etc.] and it can eat your lunch if you want to add some turns'.![]()
Wonder if a DQ250 could be fitted? It's good for 400Nm, same as a F40 transmission. I'm sure the mounts are completely different and adapting to an Ecotec would likely be difficult. Would be better off using an EA888, which can easily put out 350hp with (mostly) stock internals. Curious if DF has looked into the VAG fwd platform as an alternative to the Cobalt/HHR platform?My answer is usually "it's as fast as I can shift".
With relatively short gears and the power to weight ratio, I'm always amazed at how much time I spend shifting vs accelerating. With a PDK, I bet my 0-60 would be cut in half. The car i'm sure is capable of doing it in less than 3 seconds, but I don't know if the driver is.
Had a lot of sport bikes challenging me to races, all of a sudden. The car is fast, but it's not crotchrocket-fast.
Spring is in the air, I suppose.
All depends on how you are racing. Dead stop street race you have a good change due to how hard it is to launch a sportbike (minus the bikes with launch control and wheelie control). Roll on from 20 or so and you’ll have problems. High speed and they will roll you, because aerodynamics and such.Had a lot of sport bikes challenging me to races, all of a sudden. The car is fast, but it's not crotchrocket-fast.
track lap times, is a different animal. Everything Will completely depend on the driver/rider.
I have 2 bikes that can get over 150. One gets a little sketchy up at those speeds, the other one is no worries.
Too much for me!!! I won't be the next guy with a wrecked Goblin!
Still a mystery to us. We did a local roll call when we heard the news Sunday. All of us in the area have each other’s number, or at least we thought so. Might have been an out of town’er in for the tx2k or whatever that was called.On the topic of wrecked Goblins, do we know who's crashed on I-10 in Houston the other day? I seem to remember seeing a post in one of the Facebook groups about it
