LNF Engine parts
C
I have some things left over from my build that might be useful to someone here.
LNF Head (refurbished with new valves) $150
New timing chain kit (will need bolts for it) $50
Powered Coated valve cover - illusion blue- $100
K04 Turbo - 65K miles when the engine was torn down, no impingement on the blades, bearing are tight and not leaking - $160
K04 Turbo - 35K miles when the engine was torn down, no impingement on the blades, bearing are tight and not leaking - $200
New exhaust manifold - $100
ZZP Head stud kit- $60
My build log explains why I have all these spare parts. Basically, I end up rebuilding an LNF and found out the block was no good. I am located in SE Michigan if you are interested in any of it.
