V1 Normal Aspirated Ecotec (TURBOCHARGED build)
BAR-AIR
Good Evening,
Slowly making progress on the new engine, was able to order the electrical (AutoMeter) gauge setup w/ a mechanical boost gauge. [Definitely not like the old days where you could walk into any auto parts store and pull a gauge set off the shelves - counter people (other then the older guys) look at you like an idiot]....
But reason for the post...
Setting the engine up to run E85 and last two pieces of the puzzle are the fuel injectors and the fuel pump to handle that... There are a lot of theories (and very few facts) on what is the best way to accomplish this looking for thoughts and ideas...
THX,
Bruce
BAR-AIR
Good Evening,
Looking for some information...
Just finishing the new engine and just can not figure out the thread size for the Banjo bolts for the BorgWarner / GM turbocharger (2.0 Ecotec LNF). The oil side ( both drain and intake ) I believe the anti freeze (coolant) banjo bolts are a different size... I’m in the need of two of those banjo bolts but can’t figure out the thread size to order.
In addition that thread is also used on the oil passage way plugs. Trying to get adapters to run the oil pressure and temp probs. By removing two of those plugs and using adapters to get it to 1/8” NPT for the gauge sensors. (Thought it was 12x1.5 but it’s not but it is the same size as the banjo bolts that I’m in need of.
THX,
Bruce
BAR-AIR
Good Evening,
Just finishing up the engine.
It is a fully forged engine with LNF turbocharger that has been balanced and blueprinted....
Everything is brand new....
Looks absolutely awesome...
AND
will be putting it up for sale in the next day or two ( need to add up everything approx. 7-8 thousand )
THX,
Bruce
BAR-AIR
THX,
Speaking of turbo’s does anyone have a O2 housing that they would be interested in selling??? ZZPerformance seems to be the only game in town to purchase one... So if anyone had a spare I would be interested...
THX,
Bruce
It has the K04 (BorgWarner / GM turbocharger 2.0 LNF)
BAR-AIR
Good Evening,
Just finishing up the turbocharged 2.4 (and YES I do have it for SALE in the classifieds - it’s a lot of HP for a Goblin it should be well over 450 mark)...
So here are some updated photos....
AN fittings for the radiator lines...
Thought some of you would like the new threaded in oil dipstick....
Did have a couple of questions with regards to the BorgWarner turbocharger I have a green circle and a blue circle would anyone have photos of the connectors that attach to each of those....
THX,
Bruce
Bruce here's a photo of the intake side port. Has a plate that bolts into the single hole with a stainless braid hose that goes to the valve cover. Assume this will supply constant vacuum to the engine internals.
BTW, that is where a catch can should located to keep oil mist out of the turbo impeller and further along into the intercooler.
BAR-AIR
Good Afternoon,
Any kind of part number on the connector? Have you had it off to see the back side of the connector ( wondering if I can just machine a flat plate with a AN6 fitting then run AN lines to a catch can then into the valve cover ). How about the other (green) circled connector that should be going to the throttle body though the intercooler so there should be a bolt in connector with either a place to connect the rubber (silicon) hoses or a VEE band for hard lines. Correct? Anyone doing one of these conversions is going to need these parts would have though them readily available but can’t seem to find them anywhere....
THX,
Bruce
Bruce the photo is from my new crate engine, which I don't plan to disassemble any time soon. Sorry, no visible part numbers.
The outlet in your last photo may be a Skyline/Solstice pipe?
BAR-AIR
Good Afternoon,
Found this picture on “MisterDave’s” build log... anyone have any information on what that part is (turbo charger output) for the OEM turbocharger... everyone I have seen doesn’t have it connected to the actual turbocharger...
THX,
Bruce
These are the turbo outlet pieces I have. Left one is the DF supplied and the right one is from donor LNF engine (2008). The PN on the GM piece is 12597373. Also has 'LM 2' on the casting.
BAR-AIR
You wouldn’t be interested in selling the LNF one would you? Have a call into Adam to see if I can buy one from them also....
BAR-AIR
Good Evening,
Just doing some finishing up of the engine. Installed a pressure sensor with a 12x1.75 to 1/8 NPT adapter. I also wanted to add a temp sensor but have not been able to find a deep enough adapter (temp probe bottoms out in a normal adapter). If I was smarter would have drill and tapped the oil pan for it when I had it apart...
So you can see the pressure sensor bulb to the left of the oil filter...
Question does anyone happen to know if the plug circled in red is a 1/8 NPT thread (plug uses a 3/16” Allen wrench). It looks really close of coarse I have the engine full of break in oil (actually pressurized the system just to oil everything and check for leaks). If someone knows it would save me draining the system just to try the temp probe....
THX,
Bruce
BAR-AIR
Good Afternoon,
Bit the bullet and drained the oil... Auto meter oil temp prob threaded right in to that plug in the oil pan. (So either it actually is a 1/8NPT or the brass prob adjusted to a metric tread size that’s nearly the same size???).
So that makes life a little easier.
Bruce
