Powder coat water tube?
95Blitz
95Blitz
So I have the tube that runs from the water pump to thermostat out right now. Do I powder coat it or not? The access cover is black and the water pump housing(removable one) is orange. What do you guys think? Oh I am doing the coating so no outside cost.
Fozda
Could use VHT primer and paint. I just did mine in that entire engine in it. We’ll see how it holds up. It’s advertised as tolerant to degrees minimum
I'd recommend taking these tubes out and plugging the holes with some nice stainless pipe plugs. It really cleans that area up nicely!
38519
38521
Vwsaabvt
Didn't realize the flow would be the same. Might do this for looks, if I get ambitious. :D
I haven't really looked at the lnf thermostat housing so Im not sure if you can do the same, but Silverback cleaned his up with some different fittings as seen here. I have two of the 90* fittings if you want them to try it you can have them.
Nah, thanks anyway man, maybe someone else will take advantage of your generosity though.
