V1 Reuse REAR Disk Calipers with Mechanical Parking brake from a 2007 Pontiac G5 GT
GOB342
New Member
Two Questions
1) Can I used these calibers and rotors VS Rear Saturn Calipers and rotors?
2) Can I Purchase the Adapters by themselves?
Thanks
k.rollin
The 10" disc brakes from the base model cars were the original rear brakes for the kit, but the parking brake kit was developed to use Solstice/Sky components instead.
k.rollin
But that would have been the front brakes not the rear with parking brake?
That's right. The Goblin was not originally developed with consideration/provisions for a parking brake, which is why you'll find some earlier builders using modified go-kart or Wilwood spot brake calipers instead of the currently offered Solstice/Sky solution.
