Some build updates include QA1 tech support, powder coating round 2, and NACA duct install.
I spoke with QA1 who said the shock end/eye should be about 1" and the bearings should be just under that. Mine are the opposite with the largest shock ends measuring just under an inch and the smallest measurement I could get on one of the bearings at just over an inch. My caliper is a low-grade HF unit, but regardless of its accuracy these measurements are relative and QA1 confirmed the bearings should measure smaller than the ends and are definitely slip fit.
View attachment 31874View attachment 31875View attachment 31876
They asked if DF swaps out the bearings and I sent him a pic of how they were shipped in the original QA1 factory packaging. He wanted a pic of the box end so they could check the lot and make sure they didn't have a production issue. He is checking his inventory and is going to send me the smallest bearings he can find. It was a pleasant customer service experience.
I received the second mount for my Option B tank and dropped it off at the powder coater. They have a minimum so I checked for any other parts I wanted done. When I sat down to assemble my uprights, I realized I painted the rod ends that came with the kit but I did not paint the upgraded lower rod ends that I also ordered. Since I couldn't assemble my uprights, I threw 2 of the painted rod ends and the unpainted lower rod ends in the box to be included. Just waiting for powder coat to finish so I can get the front suspension finished up.
I received the NACA duct kit a couple of weeks back and never got around to installing it. This is another one of those things that was a lot more difficult than I thought it would be. It wasn't really difficult, just a bit like a puzzle trying to get it into place. I installed my HE after the radiator and everything else up front with no issues. However, I had to pull the radiator and hoses to get the HE and plenum assembly crammed in there. I almost took off the radiator support but ended up not needing to. It was more difficult because I had the silicone installed on the plenum's tubes. I thought about taking them off, but they were difficult to get on the tubes out of the car and I thought it would be near impossible to put them on once the plenum was installed. In any case, it's installed. My only concern is the brake/clutch lines up front. There's a lot of stuff going on up there, with the pipes, hoses, and HE all sort of riding on those lines. I had to bend one of the hose clamp tails around to keep it from rubbing on the lines.
*Note to future builders: If you are installing the NACA duct kit, install the HE and the plenum before everything else up front to make it easier and to preserve your paint/powder.
The next big items are to finish cleaning up my engine harness and to get the new seat brackets installed so I can finalize my steering placement.
