SOLD Ecotec Billet Fuel Rail OTTP $175 Shipped
RobC76
RobC76
Brand new
Description
Replace your factory rail with this billet 10AN rail. Designed to replace the factory LSJ rail but will fit 2.2L and 2.4L engines also.
We also sell two fuel line kits that contain everything needed to connect to the factory feed line. If you are using the stock feed line or our stock feed line replacement, you will need the short line to run this rail. The other option is our full length line to replace the factory feed line all the way back to the fuel filter.
Fittings: -10 AN ORB ends
Specs: 6061 aluminum, .800" internal bore
