V1 Tailight wiring help needed
PHENDERSON
P
I have the DF supplied taillights which have the 2 connectors, one with 2 wires and one with 3 wires. Does anyone have a diagram of how the 4 harness wires are connected to these? I looked but only found info on non-DF supplied lights. Thanks!
LED lights will only light up with the electricity the correct way. So if you take the wires to a 12V battery, and try different ways to wire it, it will either light up the LED or not, but won't cause a short. Play with the wires until you learn what wires are the reverse lights, running lights, and brake lights.
Passenger side:
bottom 3 wires, black and red in port 1 and 2 on my connector, port 3 is red for the top 2. Port 4 is the shared whites (grounds).
Ground, low beam, high beam, daylight running light? Grab a 12V battery, and test them, you will figure it out.
