Adam in CLE
- Adam in CLE Well-Known Member
At 7 minutes into video 4 there are 4 wires that were draped over the fuse block where 2 are moved to the body multi-plug wires that were prviously cut and 2 are left on the fuse-block. The green wire, where did it come from? Is it hunter green or sea foam green? The hunter green goes into the ECU as is uncut. I have a 09 TC model.
