According to several forum discussions, outside of the Goblin forum, the LSJ has a 67.4mm diameter, not certainif this was referring to the throttleplate diameter tho.
Yeah looks like the 08 is also just over 2.5" at the inlet and has a small neck down before the blade. The LSJ has a bigger inlet just over 2.6" but has a much bigger neck down before the blade.
Did you need to reprogram any computers? I’ve rewired mine and when I turn the key it responds with a small open close sequence. However when the car is off it does not open or close when throttle is applied like the old one does. I have been using your images plus these from the OEM manual
Other than the tune itself, no. I got the ZZP harness and it was plug-n-play. Put your donor information in your signature. Hard to say what the issue is without more info.
