Why not drill the rivets off and strip the powder coat? Should be an easy fix.
This was groundedView attachment 5094
The big ground from the white fuse box plug must be grounded.
Great idea on the lugs. I will add some prior to my powdercoat.The only other place that powder coating could cause a grounding issue is the pedal box.
If the powder coating insulates the pedal box and then you run grounds to the pedal box you could have a ground problem.
We have not had a problem with the engine or pedal boxes being insulated with any of our builds but we believe one of our customers had an engine ground problem.
We are going to add a ground lug to the transmission mount so builders can run the original engine ground wire to the frame.
It still leaves the pedal box as a potential grounding issue. If someone suspects they may have a grounding problem they could run a large wire from the pedal box to the battery ground cable.
