escapepilot
That does look like the evap solenoid. If you need it where you are, I have one you can have.
I'm good, we are moving to Arkansas soon and they don't smog. I don't plan on trying to register in NV before we leave. Thanks though!That does look like the evap solenoid. If you need it where you are, I have one you can have.
Huge help here...You were totally right about the shocks being threaded way too far into the body.I'm going to take a guess just looking at your last picture and seeing the cv axle at an upward angle that you threaded your rear shock all the way into the coilover body. Check this thread https://dfkitcar.com/forum/index.php?threads/transaxle-angle-help.3761/#post-75326
after you get your rear coilovers set correctly, then follow the DIY alignment guides for rear then front, once they are set then check to see how even it looks to you. It looks like you are trying to use your tires as reference point when showing angles down the frame, without an alignment it will look way off.
Rear end alignment
Front end alignment
You're the man. Thank you.This is the scheme I used and it worked first try.
Harness Pink(Red?) to Mirror Yellow
Harness Orange to Mirror Green
Harness Green to Mirror White
Mirror wiring
Does anyone have the color order of the wires for the side mirrors? I know on one thread they have matching colors that go to different wires (all orange, red, and green but match differently). My chassis wires are orange, red, and green, then the mirror wires are green, white, and yellow. I...dfkitcar.com
there is always Montana...no sales tax, no emissions, $50 a year after you pony up for the LLC.I'm good, we are moving to Arkansas soon and they don't smog. I don't plan on trying to register in NV before we leave. Thanks though!
