My radiator fan has never turned on by temperature.
I tested the relay, and it turns on, so the motor works.
Then I was playing in HP Tuners, and found that I could turn it on by changing the Fan Output 1, Current State 0, to 1 (step 4 below).
Fan Output 2 & 3 did nothing to the radiator fan.
Once it turned on, I tried to turn it off by changing tables 1, 2 and 3 to "Fan Desired %" to zero..
but nothing I changed would turn off the fan. I had to go back to step 4(above) to turn it off.
So HP Tuners can turn on the fan if the fan output is set to 1 for the current state of 0.
The fan turns on 100% full speed, no matter what...
Weird.
I don't know what to do next to fix this.
I don't understand what the "states" 0-7 are.
What does HP Tuners use to determine that the state has transistioned from 0->1?
My car doesn't seem to change states.
The front dash knows the engine temperature, and watching that, I have succeeded in getting the engine temp up to 210F, when the car is left idling while parked. Driving it brings it down to 180F. So the car isn't overheating, but it doesn't try to use the fan.
Any ideas?
