Also because it looks better that way!Chopped the ears off my nosecone and added a new graphic because why not
That’s really helpful thanks. Can you tell me what the diagnostic system check on 6-91 says?I wonder if the freeze frame data stores voltages for these sensors at the time of failure. Might want to look into that. I think VCM Scanner will show it if you have HP Tuners.
Thanks. I’m beginning to get really fuzzy on timeframes. I don’t think I had this problem before turbo. I’m not saying they’re related, but I don’t remember having this problem before then.I have two things that i feel it could be. You have had this intermittent issue since day one correct?
Since it is on circuit 1. one of the sensors you cut out A/C pressure sensor or Fuel tank Pressure sensor. Is getting a ground some place.
Where I would start though is the APP sensor it has been a problem across the board for gm vehicles. Change out the pedal assy. and see if that fixes it first.
Just my 2 cents
Ok. So if not before the turbo you changed MAP sensors correct? If so it is on circuit 1 also. Look thereThanks. I’m beginning to get really fuzzy on timeframes. I don’t think I had this problem before turbo. I’m not saying they’re related, but I don’t remember having this problem before then.
I don’t know what that is so I guess not?Did your model come with a short pig tail adapter that hooks up to the gas pedal?
yes once it’s out and driving again I’ll do just that.Can you post a picture of what that looks like with just lows and then with however you have it setup for highs? Showing both left and right headlights. I was trying to find a single row setup like yours last night that supports low and high but gave up and just got 2 sets of 3x2's. I wondered how something like this would look.
