1988 Nissan B12 Sentra sleeper build
I normally wouldn't bring this up but seeing this is a Nissan build.
Have you seen what some are doing with the CD009 Nissan transmission. Supposedly a very strong transmission and substantially cheaper than Tremac stuff, at least on new ones. It does require cutting off the bellhousing and running an adapter.
Just something to think about if you haven't sourced your trans yet.
Goblinfanclub1234
yes I considered it for sure, I still might, I like how tiny the TKX is. I am using Holley Terminator X and they have a plug and play TKX wire harness that is looking very easy to install, I also like all of the shifter location adapters I will find the right one that allows me to re-use the old nissan center console for maximum sleeper effect.
side note....construction has begun on the rear cantilever suspension. Each one of the pivot plates is double layer 0.135" steel with 0.135" perf inserts welded in. I am just going to build this on my bench from my engineering drawings, fully assemble the rear, and lift it into place at ride height and connect the dots to the chassis. Already had it all mocked up and took all the measurements to make this drawing and did all the engineering to size components.
44850
44851
I am sleeving the top tubes holes to prevent crush from the (6) 5/8" grade 8 subframe bolts.
44852
44853
44854
44855
44856
44857
44858
Goblinfanclub1234
I have now realized that I need a floor mounted pedal box and I need to ditch the brake booster and my turbo headers and downpipe are going to take up most of the rest of the firewall. I like this idea so much better than trying to fit clutch master into the firewall, the nissan clutch was cable. I could have done a cable clutch that might have been cool too.
50355
50348
50349
50350
50351
50352
50353
50354
Goblinfanclub1234
last piece of metal fab to mount the subframe getting laser cut now. after I mount the coil overs the roller is done!!!
just like a normal Miata the entire drive train can come out in 1 piece with 16 bolts and 4 coil overs removed
custom front rad support tube with cutouts for more airflow to radiator
water to air heat exchanger
power steering cooler will fit between the hood latch support and the heat exchanger
50965
50966
50967
50968
Goblinfanclub1234
2 weeks away from being a completed roller!!!! boxed in OEM frame = pretty big brain stuff. Still need to add more gussets and stuff.
miata front suspension fit nice. I realized that I needed to shorten the front strut towers a lot since the McPherson strut is changing to a double wishbone. makes me appreciate how compact the Miata suspension is. I can swap a Miata suspension into anything now.
engine bay progress video
51182
51179
51180
51181
Goblinfanclub1234
I have my Tremec TKX mounted now working on build a cross member. small and strong, I also needed to move the shifter back and the TKX has multiple shifter locations :cool:
I see you notched and lowered the top of the tunnel a bit, better fit to the bellhousing or top of the transmission? Or is this to accommodate the dash panel?
