ryanthecarguy
I have a DF goblin kit car that I bought 3rd hand and uses a 5-speed 2008 Chevy Cobalt SS TC as it's donor.
I had to engine swap with a new third gen due to porous block from my LNF. Now the car doesn't crank using the key. Will crank when jumping the starter relay. After cleaning a bunch of corrosion, and tracing the circuit backwards with several continuity tests, I find that there is only 9.3v coming from the ECU to the signal wire mind you, when the key is turned to run. Turning to start has no change. I scraped off a little insulation from the purple and white wire right next to the X2 plug to be absolutely sure. Am I in need of a new ECU or am I missing something?
I should mention that the clutch position sensor is zip tied to simulate the clutch being pushed in.
