Sorry to here that BCM isn't the actual problem.
Don't put in a larger fuse. That is asking for a melted wiring harness or worse.
I'm confident in the work we did tying this to the C4 connector or wiring leading to the C4 connector. You are going to have to start tracking down the outputs of the BCM which isn't going to be easy. You can probably eliminate any of the higher load circuits fed from the 40amp BCM 2 fuse. Look for feeds going to the other modules and the 5v reference type circuits. At some point you are going to pretty much have to find all of the wiring diagrams and connector pinouts for you donor and work to eliminate them one at a time.
You might want to rig up or buy an incandescent test light and probe all of the pins on the BCM connectors. You will look for the ones that light up full brightness and then work out which ones of those are likely to properly go to ground. You could try this with the OHM meter and see what the resistance is but I would prefer the light bulb test.
I also could see this coming down to deliberately and methodically cutting the wires one at a time until you find the problem.
