Bigfoot Goblin
Ark, if you can borrow an inspection camera do it or maybe see if O'Reilly's or Autozone has one they can loan to you. Don't spend money on the camera (unless you really, really want one) and save your pennies, you are going to need them on this one. Broken lifters are an indication the inside of the cylinder is going to be armaggedon with bent/broken valves and likely gouges/holes in the tops of pistons. Someone did something bad to this engine and it may not be salvageable. As Ross stated, if you can save the block and crank from the engine internals it will be a miracle. Sorry you had this happen. I'm sure those of us in the Goblin family will do what we can to help, but this may end up being a search for another engine.
