So maybe I'm the first to get to this point with the ATK long block. I can confirm that the Standard S1458 will connect to the 12612110 MAP sensor. I gave almost $40 through RockAuto, although it looks like it is the same as ISUMO by the same # on Ebay for $22.
ZZPerformance has the 4 Bar Map on their site and says;
Tune tweaks:
Map sensor Linear reads 94.4 in the stock 2.2/2.4 ECU file and this needs to be changed to 424.99. The KPA offset is 10.3 stock and should be changed to -32.50.
I have also found on the HP Tuners forums the recommendation to copy the MAP data from the stock Buick Regal Turbo tune.
I actually have HP Tuners but haven't actually ever used it so I might need some help when I get to that point to get this tweaked. I likely need to reload and modify a stock tune since the tune I have know is likely a ZZPerformance tune and I don't know how well that will work without the ZZPerformance intake mods that were on the Donor.
