redline
Hello guys,
I have been fighting this problem for quite a while. I have had the car aligned many times at different shops and always the same result. I am now running ET mickey Thompsons on the rear and they are 325's and triple 5's on the front which are 315's. It goes fairly straight while under power during a pull, but as soon as you lift off the gas the car starts swaying. If i do a pull up to 130 the sway is so bad you can't stay in one lane. I run 22psi on rear and 28 on fronts, but I have played with this a bit with no conclusive evidence. I am starting to suspect the steering box??
any thoughts?
any thoughts?
