The POR15 prep is an etcher but not a primer, so it will not coat the steel to prevent rust over time. It is meant to prep the steel to bond with the basecoat when ready to paint. If you are worried about rust - and will be using the POR cleaner and prep steps before doing the basecoat - you could spray the steel with a misting oil. That way you will not have to try to remove a paint primer from the chassis when you are ready to apply the POR15 basecoat. The oil should come off easy and help prevent rust/further rust, within reason. SE primer is still a paint and even though it 'self-cleans' the steel it still does not chemically bond to the steel as the POR15 basecoat will. This is just my 2 cents of opinion.
