Bought the kit from
BCRacing-na.com, they are the distributor (don't go to BCRacing.com, the manufacture). There is list of items you buy from them individually to make up a custom set needed for the goblin. Each item is order individually so if you don't want the dust boots, you don't have to order them, the same goes for the bump stop and the spanner set. Even though the website stated the plastic coil spring seats come with the lock ring, they don't! I showed them their website said and showed they do, so they threw them in for me.
There are a few custom items you will need from DF to complete the setup. Sorry I don't have those items numbers with me, contact Adam and he can help you with them. You will also need the springs and spring caps either from BC Racing or QA1 for your setup. You will need to determine the spring rate setup. DF suggested using the 300# from the front and installing them in the rear and using 400# in the front. That's what Lonny's car had, and that is what I'm going with.
The items ordered are:
1) Front shock cartridge: $95.00 each plus shipping
ORDER 2
https://www.bcracing-na.com/product/br-series-front-damper-280130mf120m12-1?gfid=p1844-c10087
2) Front right lower mount: $50.00 each plus shipping
ORDER 1
https://www.bcracing-na.com/product/lower-mounts-front-right?gfid=p1463-c7522
3) Front left lower mount: $50.00 each plus shipping
ORDER 1
https://www.bcracing-na.com/product/lower-mounts-front-left?gfid=p1462-c6985
4) Lower spring seat
53mm: $7.95 each plus shipping
ORDER 2 Make sure you order the correct size
https://www.bcracing-na.com/product/lower-spring-seat-uppermost-lock-ring-2
5) Middle lock ring
https://www.bcracing-na.com/product/upper-lock-ring-middle-lock-ringspring-perch
6) Lower lock ring
https://www.bcracing-na.com/product/lower-lock-ring-lowest-lock-ring
7) Plastic spring seat isolator: $5.00 each plus shipping
ORDER 2
https://www.bcracing-na.com/product/spring-seat-isolator-plastic
8) Bump stop: $5.00 each plus shipping
ORDER 2
https://www.bcracing-na.com/product/bump-stop-20mm-best-quality?gfid=p2791-c23287
9) Adjustment knob
M12: $7.95 each plus shipping
ORDER 2
https://www.bcracing-na.com/product/br-series-adjustment-knob-m12-best-quality
10) Dust boot
20mm: $5.00 each plus shipping
ORDER 2
https://www.bcracing-na.com/product/dust-boot-20mm-best-quality?gfid=p2781-c21797
11) Spanner wrenches: $25.00 plus shipping
OPTIONAL - ORDER 1
https://www.bcracing-na.com/product/spanner-wrenches-sg12-001-002?gfid=p2176-c24107
12) M12 x 1.25 FINE thread lock nuts of your choosing
Order 2
https://www.ebay.com/itm/142691303285
13) QA1 Spring Caps
Order 2
https://www.qa1.net/suspension/street-performance-racing-shock-accessories/coil-over-kits-components/spring-caps
***EDITED*** 02-08-2019
Here is the initial adjustment I have for our ride height of around 7" to the bottom of the subframe. Yours will vary, but this will at least get you a good starting point.
